Mobile data not working
tofupunx
Mobile data has stopped working about 95% of the time.  Sometimes it works briefly.  Prior to this issue I have made zero changes to my phone.  I looked through the forums and tried a lot of the solutions offered by other users with no luck.  I also used the chatbot and had no success there either.  Submitting a ticket keeps failing and sends me back on the chatbot loop.  Can anybody help!?
2 REPLIES 2
tofupunx
At the moment it seems to be working after  resetting network settings.  Hopefully this is  fully fixed and not just sporadic.  I’ll submit a ticket otherwise.
Thanks for the help!
@tofupunx  Try resetting network settings . Also is it possible to try the SIM card in another phone to test . But to submit ticket to support try this link
private message   To CS_Agents click
