09-14-2020 11:49 PM - edited 01-05-2022 03:53 PM
I just got my plan today and my mobile data isn't working yet. It's turned on in settings but it doesn't show up or work when I try to use it. Will it activate soon or is there something going on?
Service
09-15-2020 02:05 PM - edited 09-15-2020 02:06 PM
@kb_mv wrote:I wonder what determines why a certain phone needs to have the APN entered manually. I have a Sony Xperia X Compact which I believe is a year older than the OP's XZ1. When I signed up recently for a 2nd account with PM, I put in the new sim and the data worked flawlessly. Just curious.
This is completely dependednt on the device manufactuer and them having the setttings pre-programmed into the phone's software.
09-15-2020 09:32 AM
I agree with the wonder. I first had a BB running OS10. No problem. Then I got an S7 running A8. No problem. Then for another account and to dabble around with a Nokia running Windows 8, I did have to fiddle with the APN. Then I "trialed" an A31 running A10. No problem.
So I wonder too.
09-15-2020 08:03 AM
09-15-2020 03:58 AM
Welcome to public mobile. We're always happy to help!
09-15-2020 01:54 AM
Thanks so much for the warm welcome! So happy to have found such an amazing community ❤️
09-15-2020 01:53 AM
Thanks so much! To you and to everyone who helped me out! I used this link and entered the APN in the access point settings and my data is working!
09-15-2020 12:40 AM - edited 09-15-2020 12:41 AM
@Andyy wrote:I just got my plan today and my mobile data isn't working yet. It's turned on in settings but it doesn't show up or work when I try to use it. Will it activate soon or is there something going on?
Hi @Andyy here are two links you should read about setting up data:
Set Up Data On An Android Phone
or if you have an iphone
I hope this helps. Let us know what happens. Cheers!
Welcome to Public Mobile and the Community!
09-15-2020 12:39 AM
09-15-2020 12:36 AM
@geopubli
Sony xperia zx1
09-15-2020 12:10 AM
@Andyy Also what's the make and model of your device?
09-14-2020 11:51 PM
You'll likely need to enter APN settings.
Sometimes having cell data on and restarting might bring it in from the carrier.
Or maybe post your current APN settings and we can see if something should be different.
