Mexico plan
Ydni
Is the Canada US Mexico plan good in Mexico or just to call Mexico from Canada?
Bdah
Hi. I have the Canada/US/Mexico plan and am currently in Mexico. For some reason I do not have any data unless connected to wifi. I must turn “data roaming on” in order to be able to text or use the internet. There is no public mobile network here, so I assume that’s why my phone needs to roam. However I am a bit worried that I will end up with expensive roaming charges. Does anyone else have this issue?
slusagm
The Canada US Mexico plan is good to be used in both US and Canada as well.  You can use voice , text and data in both Mexico and US like you are in Canada
