Manual for My Settings - Community
semenoar
Hello,
Just wondering if there is a manual that will help describe the My Settings - Community & all it's associated functionality & options in more detail?
Thanks in advance.
srlawren
@semenoar got a response back from the Lithium folks, and they pointed me to some info right here from our community, which might help.
For tagging and tag clouds, see http://productioncommunity.publicmobile.ca/t5/help/faqpage/faq-category-id/tagging#tagging
For macros, see the answer to the 'can I create "canned" or "boilerplate" responses' question here:  http://productioncommunity.publicmobile.ca/t5/help/faqpage/faq-category-id/posting#posting
srlawren
@semenoar I have found some possibly useful info on the macros:
https://community.secondlife.com/t5/Everything-Else/What-are-Macros-in-My-Settings/qaq-p/705625
I also found an extensive Tagging guide (https://community.lithium.com/lithosphere/attachments/lithium/lithiumblog/524/1/Tagging.pdf), but it appears to be aimed at community administrators and talks about configuring the community itself, not really from a community member's point of view.  It still might give you some background on what tags are and what they are used for.
srlawren
Hi @semenoar, sorry for the late reply!
I'm trying to track down some info for you on these features but so far no luck.  The community is powered by a Lithium system, but they seem to be locking down all of their guides.  I'm hoping to get a reply over there soon, and will share whatever I can find out.
semenoar
@srlawren
I guess just getting an understading of the tagging & macros tabs would be good for now. The first few options in tagging are self explanotory but the remainder are a little foregn to me. In terms of macros how are they used and for what.
Thanks in advance.
srlawren
@semenoar none that I know of.... are there are any settings in paritcular you are curious about?
