06-23-2017 06:48 PM - edited 01-05-2022 02:15 AM
06-23-2017 07:37 PM
I as well made a mistake when setting up my plan and did not select "Unlimited Global Text". Can this be corrected?
06-23-2017 07:16 PM
Just did, thanks
06-23-2017 07:16 PM
@lammer03 As mentionned above, send a private mail to the moderators and they should fix that for you as well, just like the OP situation.
06-23-2017 07:08 PM
Now that you said it, I went back to check, lol. Made the same mistake too...
06-23-2017 06:57 PM
Send a private message with your sim number, phone number and your email to the Moderator_Team and they will get back to you.
