Loyalty program
shelby72
Hi, just changed my plan and I noticed my loyalty program was not applied on my billing
ShawnC13
@shelby72, if you made a change prior to your normal renewal date your rewards will not be applied.  Rewards are applied on renewal dates only (so if you chose to change your plan on your renewal date they should have been applied).
@shelby72
you can Logout Self-Serve and do clear cache and cookies for any Browser,
and use a Browser from your computer,is better
use Browser microsoft edge or chrome latest version
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
for microsoft edge how to update your browser visit Here
and Restart your computer, is will help a lot,
and sign in to Self-Serveand maybe is take from 24 to 48 hr to you will see it,
Triguy
  • If you’ve changed your plan prior to your current plan renewal date, you will receive your Reward credits after you have paid for the new plan, within approximately 24 hours. Rewards will be applied normally from then on.
Dtack
@shelby72  - I believe you will have to contact the CSA to resolve this issue.  Try using the chat box.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
Good luck!
