Lost phone
Options
03-04-2015 05:02 PM - edited 01-04-2022 01:07 PM
I lost my phone in my house. The phone is on but the ringer was turned off. Can public mobile or telus send a sound or locate the phone?
Labels:
Service
1 REPLY 1
Options
03-04-2015 05:25 PM
Hello,
Tells nor PM cannot do either.
Did you download any apps that are intended to "yell" if a phone is missing, lost or stolen? I so, that is your only option, before the battery runs out of power.
If the above doesn't apply, a manual search for your phone will continue to be necessary.
Good luck!
Good luck!
