Lost email
Navipadda
Hello
plz help me to get the email and password to update my credit card
my old email also not working [email protected]
@Navipadda wrote:
Hello
What do you mean "old email also not working"? Do you no longer have access to that email box? Or that the Forgot your password? link isn't giving you the reset? Do you know the answer to your security question? (don't type that here)
But anyway...as already mentioned...the moderators.
NDesai
@Navipadda You should already know your email and password that you entered during activation. If you completely forgot what email you used, check all your email inbox and see which email Public Mobile sent the welcome email. Or try resetting the password and see which email get recognized.
If you activated at the store, then you must register for an account here: https://selfserve.publicmobile.ca/self-registration/
hycm53
@Navipadda wrote:
Hello
Contact moderator team:
edited by computergeek541 to remove personal information
