Loop in app
GEOFF007
Hello, I want to share my experience with the PM app. It was stuck in a loop. Multiple attempts to login and it would repeatedly take me back to the login page. (I received the text 2fa then it would restart the process)
I was checking the box Labeled : Make this a trusted device. Leaving the box unchecked allowed me to login. (Also FYI it seems you can't copy and paste passwords in the app). Thanks
GEOFF007
I was able to get it to work by NOT selecting the "trusted device" box. Also I had to manually put in my password. (Not copy and paste). Good luck
Doukhobor
Turns out I was using an old account login, and not my new one.  Nevermind, nothing to see here.
MYTH-BUSTER
I am having the same issue, fresh install.  Can't login in app, just loops back to the main page.
I also cannot login to the website, again it sends me the 2FA code, I enter the code, and it just resets back to the main page.  I click on MY ACCOUNT and nothing happens.
HI @GEOFF007
probably app cache problem, try uninstall and reinstall the app
for for password copy, it could be done on purpose as a safety feature, many bank apps do that
