09-14-2018 04:05 PM - edited 01-05-2022 01:48 AM
Hi, I just activated
$50 for 8 GB at 3G speed
- 30-day plan
- 8 GB of data at 3G speed
- Unlimited Talk to Canada-wide and the U.S.
- Unlimited International Text and Picture Messaging
- New and current customers are eligible"
My question is do I still need to add-on a long distance to make call when travel outside my home provinces?
Thanks
Joining Public
09-16-2018 10:39 AM
Thanks you.
09-14-2018 04:33 PM
@acer38 wrote:Hi, I just activated
- 30-day plan
Thanks
- Unlimited Talk TO Canada-wide and the U.S.
- If you leave Canada then you need roaming in the US or you're out of luck elsewhere.
09-14-2018 04:21 PM
@acer38 I do recommend reading the Terms and Conditions at the bottom of the Plans page. There are some exceptions to the US calling And US roaming, specificly item 6.
09-14-2018 04:18 PM
Nope...you're good to call Canadian numbers.
09-14-2018 04:14 PM
- 30-day plan
Thanks
This plan is for Canada wide so you won't need anything out side you own province within Canada. However if you travel to the US than you will need a US roaming addon to make calls, text and use data.
