Login
Pamr57
Do I have to have a confirmation code every time I login? Even if I’ve indicated the device is trusted?
@Pamr57
Yes, it works without confirming the 2FA code every time on the PM app but it is finicky on this Community when connected to public wifi.
will13am
I find the trusted device option to be somewhat unreliable.  I don't clear cache for the site but from time to time, I am required to redo the trusted device setting.
HI @Pamr57
the trusted device supposed works well.  It works for me
but some people have prople because they use browser with the option to clear cache one exit.  For trusted device to work , you need to use cache and not delete it
