Log Out symbol
blizzard736
I cannot find Log Out from the account. Probably looking at it and just not seeing it... 🙂
Very new to PM. Thanks in advance.
Click on the your user avatar (picture) near upper right corner, then "Sign out".
But you may need to disable scriptblocking for this site to get this function working properly.
The other option is to delete cache/cookies in your browser, for this site or for them all. This forcibly "logs off" any active sessions on the browser/client.
Gunner123
RosieR
Hi @blizzard736 click on your avatar on top right.  a dropdown menu will appear and log out is the last on the list.
blizzard736
Well, there is nothing there on my screen...
Gunner123
@blizzard736 hi if you mean your self serve it is in the top right corner just below my account  edit OIC you mean your community account
