01-13-2026 04:43 PM
I cannot log into my wife's account. Public Mobile does not recognize either her email or password. Am I using the incorrect phone format perhaps.
01-22-2026 02:28 PM
self solution removed
01-22-2026 11:15 AM
The problem is resolved. My wife and I both have accounts and with PM's help I finally obtained the correct email address for her.
01-13-2026 04:55 PM
It is alway better to download the PM app on all phones with different accounts then login for that phone. Also click on trusted device when login.
This way there are no mixups for different accounts. Just contact a CS_Agent to help you login to your wife’s account.
01-13-2026 04:47 PM
hi @Menyanthes
when you have multiple PM accounts, best to use Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in), this is to avoid cache problem
and if you cannot login your wife's account, try the click Forgot email on the login page
if same, then you will have to ask PM support agent to help. You can submit ticket by direct message:
