Locked sim
Nate5845
how do I fix this?
mimmo
@Nate5845 wrote:
How long do they usually take to respond and how do I fix my incoming calls?
1 hour to 48 hours depending on workload
Can you explain how you locked your sim?
Nate5845
Alex888
@Nate5845 If you locked your SIM you will need to contact the moderators to get an unlock code, you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
