Locked Account
TinaB
I forgot my password and made too many attempts.  Now I am locked out of my account and the password reset won't work.  What can I do?
2 REPLIES 2
Hi @TinaB  you can wait 60 min and try again or try Forgot Password link there
 if you are unable to reset via Forgot Password help there, open a ticket with PM Support and they can look it up and reset password for you
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. First type: "Forgot log in information"
  2. Then Click "Contact Us"
  3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
