11-19-2020 01:33 PM - edited 01-05-2022 04:10 PM
Hello, I've done some research and some of the 4GLTE bands match what Public Mobile supports with the Lite Phone 2 but not 100% positive Public Mobile supports this phone. Can anyone clarify if this phone works with Public Mobile?
Thank you
11-19-2020 02:21 PM
@Airborne wrote:As far as I know the make is Lite Phone and model is 2. This is from their website. It uses the following 4G LTE Bands: B2, B4, B12, B13, B17, B25, B26. I do believe PM supports bands 4,12,13,17 LTE. The Lite 2 is 4G LTE only. No 3G
@Airborne As described by you, this phone is not compatible with PM. The phone checker is not, and never will be, replete with every phone/model.
Network Frequencies at PM
4G LTE/LTE Advanced: 700 MHz, 850 MHz, 1900 MHz; 2100 MHz downlink with 1700 MHz uplink (AWS). PM throttles speed on these to 3 mbps.
HSPA (3G): 850 MHz, 1900 MHz (UMTS). N.B. Must have these for calls to work. Texting and data also work on the 3G frequencies.
Public Mobile has partnered with willmyphone work as the new compatibility checker. If you can’t find your make and/ or model here: https://www.publicmobile.ca/en/on/get-started, provide feedback directly https://willmyphonework.net/Home/ContactUs.
11-19-2020 02:04 PM - edited 11-19-2020 02:05 PM
Then you won't get voice here. You're barely getting a couple LTE bands for data and SMS/MMS.
11-19-2020 01:49 PM
Ya I know but the thing is, PM has a list of all the phones that are compatible and when I checked that list, your phone wasn’t on there so I want you to know it may not be compatible. Usually most phones are compatible, just don’t want you to get upset with PM if things don’t work out.
11-19-2020 01:45 PM
11-19-2020 01:43 PM
It does work in the states, but I don’t see any official word that it works on this network. Keep in mind there are other non smart phone options like a flip phone. The one your thinking about getting has poor call quality.
11-19-2020 01:38 PM
@Airborne wrote:Hello, I've done some research and some of the 4GLTE bands match what Public Mobile supports with the Lite Phone 2 but not 100% positive Public Mobile supports this phone. Can anyone clarify if this phone works with Public Mobile?
Thank you
Do you have a full make/model/submodel for that?
For voice you need 850 and 1900 on 3G/UMTS/WCDMA. We'll get to LTE later.
