11-23-2020 07:11 PM - edited 01-05-2022 05:31 PM
When I send a link and recieve
When I receive a link why does it come up as hyperlink not a image
11-23-2020 09:47 PM
@AdamLove wrote:Yes I can
I was not getting any fix to my problem
Please allow more than an hour for people to try to answer your questions. Creating multiple threads will only make it harder you for to find the repsonses from others. Thanks.
11-23-2020 09:06 PM - edited 11-23-2020 09:07 PM
I get the preview of the link on lg blu and umidigi phones, can it be phone related?
Can you borrow your mom's phone just to test?
Can you also dig through the message app settings and see if you need to enable it?
11-23-2020 08:48 PM - edited 11-23-2020 09:56 PM
@gpixel wrote:@Anonymous he has an Samsung. please teach him how to get to those options
Sigh. In default Samsung texting app - 3 dots, Settings, More settings - Show web previews.
Come on AdamLove. Figure it out.
I don't know if that option will give you what you want. Try it out.
Can I put my spoon away yet?
11-23-2020 08:45 PM
11-23-2020 08:45 PM
Cool thanks
11-23-2020 08:43 PM
@AdamLove wrote:How to find this setting please
Dude. You're in a hands-on self-serve kinda place. Dig around. Go around all your texting app settings. It's not hard. Explore the big wide world.
11-23-2020 08:42 PM
@AdamLove wrote:Yes
And it shows up as nice picture from the addressed video
Hi @AdamLove here's from MMS Problems on an Android on chron.com. that might help.
A soft reset clears up a range of issues on Android phones. If MMS problems persist, soft reset your phone. The soft reset, or battery pull, does not negatively affect your phone. It may provide your phone with the boost it needs to function properly. Pull out the phone's battery and leave it out for 45 seconds. Replace the battery and turn on the phone. Send a test message to determine if the problem is resolved.
A last resort option for fixing MMS problems on the Android phone is a hard reset. The hard reset removes the data on the phone and resets its settings. Back up your phone's files before doing a hard reset. Open your phone's settings and tap “Privacy.” Tap “Factory Data Reset” and follow the prompts to finish the hard reset. When the Android restarts, you will need to go through the phone setup process again.
I hope it helps.
11-23-2020 08:42 PM
Samsung a20s
11-23-2020 08:38 PM
11-23-2020 08:37 PM - edited 11-23-2020 08:40 PM
@AdamLove what's the make and model of the device?
11-23-2020 08:35 PM - edited 11-23-2020 08:35 PM
@AdamLove wrote:It's on and still no image an the link or address to video to youtube.com
I was trying to identify if you were talking about MMS notification if you didn't have data on.
My Samsung phone has an option in the default texting app to "Show web previews". Mine's off. Maybe you could turn yours on if you have something like that. Maybe that's what you mean.
11-23-2020 08:35 PM
This is a text message
And she gets a picture and hyperlink and its flashy and cool looking I want this
11-23-2020 08:31 PM
11-23-2020 08:30 PM - edited 11-23-2020 08:35 PM
@AdamLove wrote:LinksWhen I send a link and recieve
When I receive a link why does it come up as hyperlink text not a image.
My mom on virgin mobile network gets nice pictures an address.
I want this in text messages to
It may be your text message app. I am using Google Messages app from Google Play.
https://play.google.com/store/apps/details?id=com.google.android.apps.messaging&hl=en_CA&gl=US
The text messages which I received from Superstore and SDM on my $10 50/50 plan showed up as web links.
Update:
The link in Cha-ching text message from PM 611 is also shown as web link on my Google Messages app.
11-23-2020 08:28 PM
@AdamLove wrote:How can I turn on cell data
Seriously? Ok call it Mobile data. I say cell data to distinguish it from wifi.
11-23-2020 08:28 PM
Yes I can
11-23-2020 08:25 PM
Yes
11-23-2020 08:23 PM
Duplicate post.
@computergeek541 can you merge with below? Thanks.
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Links/m-p/619097#M124886
11-23-2020 08:20 PM
11-23-2020 08:00 PM
It's no file just address to the videos
11-23-2020 07:59 PM
11-23-2020 07:58 PM
When I send a link from youtube to my mom she gets a picture not just a hyperlink like I get.
I want to get pictures not just text
11-23-2020 07:55 PM
In messages to my phone number...
11-23-2020 07:33 PM
@AdamLove wrote:When I send a link and recieve
Um...because it's a link?
Sending pictures via MMS sends an actual picture...not a link. Sending a link is basically just a line of text.
You need to turn on cell data to receive an MMS.
11-23-2020 07:23 PM
11-23-2020 07:18 PM - edited 11-23-2020 07:19 PM
11-23-2020 07:13 PM - edited 11-23-2020 07:15 PM
Let us test a link and it is working.
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
In what situation where link is not working?
