Line still not activated
Bobkat80
I've been waiting 5 and half hours and still no activation is this normal
12 REPLIES 12
geopublic
Dial *#*#4636#*#* on your phone
Select phone information what does it show under Network? What does it show under phone number?
Pizzaeh
@Bobkat80 wrote:
Wrong password and when I try to recover pass work says my email is not right either. I paid with a voucher and I got and email from PM right after I signed up. But then I tried to log in and nope not allowing me access
How about your phone, what does it say when you try to make a call? Is there any message on the screen, what do you hear?
Bobkat80
@Bobkat80 wrote:
Its unlocked and and yes I restarted it and self self serve account won't allow me to log in
What does it say? (Self serve error, wrong password? no account?) Serlf serve account should be activated instantly. Are you sure it activated? Was your payment method charged?
Bobkat80
Bobkat80
Yes it's an s7 Samsung
@Bobkat80 wrote:
I tried activating my my sim and transfering my fido # around 5:50 PM and paid with a voucher, and I still have no service
Is your Fido phone a fairly recent model?  What model is it?  Some older devices may not be 3g compatilbe with Public Mobile, or may have the network type incorrectly set to 2g (which Public Mobile doesn't have).
@Bobkat80Did you restart the phone ? is your phone unlocked? Log into self serve, is the account active
Put your fido sim back in, and use that till it stops working.
Bobkat80
RobertQc
@Bobkat80Bobkits give us some details and we can try to help you out
@Bobkat80
I have moved your thread to the Getting Started category.  "The Lounge" is really only for off-topic discussions, and for matter unrelated to Public Mobile.
Your service is supposed to start working immedaitley after you complete the activation process.  I am assuming that phone calls, text messages, and data are not working?  Are you able to log into your self-serve account?
RobertQc
@Bobkat80new number or did you port in? Did you put in the sim? Can you login to self serve? Can you give us more details? Is the account active? Is your phone compatible? What plan are you on?
