04-02-2020 03:51 PM - edited 01-05-2022 10:13 AM
I want to cancel my cell phone line which is set up for auto pay but I can’t
My Account
04-02-2020 04:12 PM
@Jorgec1004 wrote:I want to cancel my cell phone line which is set up for auto pay but I can’t
@Jorgec1004 Disable Auto-Pay by dialing 611 from your device or access selfserve and remove your Credit card.
04-02-2020 03:56 PM - edited 04-02-2020 04:33 PM
@Jorgec1004 why can't you cancel the plan? Thanks. If you plan on porting your number, the account must be active and will close once the number is ported. Remove your autopay credit card before porting it out.
04-02-2020 03:54 PM
04-02-2020 03:53 PM
hi just remove your cc from your self serve account after 90 days it will be closed
