09-26-2018 10:29 AM - edited 01-05-2022 01:56 AM
Hello,
Out of the blue I have only been able to make emergency calls with my phone. I tried a factory reset, a network reset, turning the phone off and on, reseated the sim card. I am not sure if it is an account issue or phone issue. I am in halifax ns.
10-22-2018 08:35 PM
You know what I'm having the exact same issue with my G6 i woke up one morning and my phone wasn't working found out today it's not the sim and what do you know the warrantee expired a week before it did this
09-26-2018 10:59 AM
@will13am wrote:
@smp99 wrote:I assume it was working fine before
You certainly did a number of good troubleshooting steps.
I think it may be the SIM or the phone itself
Can you try the SIM in another phone and can you try somebody else's SIM in your phone.
Also, take the SIM out and lightly rub the chip side with a soft pencil eraser. That has helped me before.
I always (often) have a spare SIM on hand for me or one of my many PM friends in case this happens, and it does happen (rarely)
It seems like people blame the SIM card a lot in this forum. I have never experienced a SIM failure ever.
Most likely account is suspended
Sim Card unlikely get defected
09-26-2018 10:46 AM
09-26-2018 10:37 AM - edited 09-26-2018 10:40 AM
09-26-2018 10:36 AM
@mattg, have you taken a look at your self serve account to see if it is in active status. If the account is active, the problem is with the phone. If the account is suspended, you will need to make a payment to restore service.
