Lg 6
cindylaflamme
Hi! Could someone tell me if the LG6 6.0 is compatible with Public mobile ???Thanks!
9 REPLIES 9
@cindylaflamme If the cell variant is actually the LG g3 D852 then it has no 4g LTE data compatibility with PM. So in areas with 4g data only, you will have none. See link https://www.frequencycheck.com/compatibility/48V4hAv/lg-g3-d852g-3g-lg-b2/canada
If you have the phone, you will be able to call and text and in 3g data areas have data. Make sure it's unlocked by calling your previous provider to unlock it for you. And do a factory reset before inserting your PM SIM.
@popping wrote:
@cindylaflamme wrote:
Version D8523g
Android 6
You should update your OS version.
My older LG G5 already using Android 8.
The D852 is actually an LG G3.
popping
Version D8523g
Android 6
@cindylaflamme  I cannot find that variant. What are the band's associated with it? Can you supply us with a link so that we can see it? Thanks. These are the ones that I could find. See link https://apn-canada.gishan.net/en/apn/public-mobile/lg-g6 . They are 100% compatible with PM. Make sure your phone is unlocked and do a factory reset before inserting the PM SIM.
Karnbot13
Version D8523g
Android 6
Is that what's listed when you look in your hardware tab in the settings?
cindylaflamme
Version D8523g
Android 6
popping
@cindylaflamme
Canadian version of LG G6 should work with PM.
Please note that you need to do network reset after changing provider before you data working again.  If network reset does not fix the data issue, you may need a factory reset your LG G6.  Please do a backup you data before factory reset your LG G6.
Ask if you have more question.
CannonFodder
@cindylaflamme  If you're referring to the G6, AND it's the Canadian sub-model(H873), it SHOULD be fine....
Karnbot13
It could be. What is the model number?
