11-04-2016 06:01 PM - edited 01-04-2022 06:02 PM
Hi Everyone. I just got my phone up and running with PM. I was with koodo before this. I noticed that when I put in my koodo sim card I would get and LTE connection but when I put in the PM sim card I would only get 3d connection.
Had anyone experinced this before and how to fix it? My phone is a oneplus X
thanks,
11-05-2016 02:32 AM
@Watoko good to know Ill probably do that too. I setup my account so my email address is different from my koodo one. Right now I can't log into selfserve so just waiting on a mod to fix this for me.
11-05-2016 02:28 AM
@kc815 Did it myself through self-serve. No problems for me, just make sure your Koodo email address isn't the same as your Public Mobile one.
11-05-2016 02:23 AM
@Watoko did you port through a modirator or did you do it yourself through the selfserve?
11-04-2016 09:58 PM
Porting from Koodo is fast and easy, literally took like 2 min for the number to port, so hopefully it'll be as fast for you!
11-04-2016 07:33 PM
I just put the simcard back in and looks like LTE works now! Thanks guys for the help.
Now all i have left to do is fix the selfserve log in problem and port my number over from koodo. Fingers crossed.![]()
11-04-2016 07:28 PM
Give it time and try restart your phone. Mine was on HSPA for the first 30 mins or so and I restarted then it changed to LTE.
Make sure your APN setting is set to (Public Mobile - sp.mb.com) or you'll have to add it manually
11-04-2016 06:38 PM - edited 11-04-2016 06:39 PM
You may have to change the APN settings on your phone.
I found these steps from another post by Lachlan_M
Android 4.0 and higher :
Step 1:
Settings > More... > Mobile Networks > Access Point Names > New APN setting (or a plus sign) *Some models might have a slightly different path
Step 2:
You will need to input the following info:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Step 3: Select Save/Done. Select Public Mobile to connect to the Public Mobile network. Your data should work normally now. Hopefully that helps.
Also 4G and LTE are essentially the same thing.
11-04-2016 06:08 PM
time is a virtue 🙂 it solves around 90 percent of the problems here on the PM forums haha
11-04-2016 06:07 PM
Ok good to know, I'll give it a couple hours and see if it fiexes it self.
thanks
11-04-2016 06:04 PM
I have the same phone and just switched over, you gotta go to your cellular networks > access point names > select public mobile. also set apn type to blank
11-04-2016 06:04 PM
@kc815 wrote:Hi Everyone. I just got my phone up and running with PM. I was with koodo before this. I noticed that when I put in my koodo sim card I would get and LTE connection but when I put in the PM sim card I would only get 3d connection.
thanks,
I noticed that for the first hour or so my phone (came from Rogers) sat on HSPA and then switched to LTE.
Now I stay on LTE all the time (switching and coming back to LTE automatically only for a voice call).
I've had this happen with other carriers - it's as if it takes time for LTE to lock-in the first time. I have no idea why!
PHT
