LG-M322
DGuyArch
Can I use my LG-M322 with Public Mobile? It is from Comcast- do I need to unlock it? If so, how?
2 REPLIES 2
Staliger
@DGuyArch The phone itself is supported by PM, but make sure it is unlocked by your previous provider.
The following appears to be an specification page for a different provider, but the mdoel number is the same: LG X charge Smartphone for Xfinity Mobile (M322) | LG USA
LG states the frequencies as: "CDMA: BC0, BC1; GSM 850/900/1800/1900 MHz; UMTS Bands 1/2/5/8; UMTS 850/900/1900/2100 MHz; LTE Bands 2/4/5/13"
The phone should work, but yes, you do need to make sure that it is unlocked. That is between you and the original carrier. Third party sellers should also be able to provide the unlock code.
