LG K7 (2017) issues receiving calls
on2wheels
I’m using a Xiaomi phone and have no issues making or receiving calls. When I try to call a family member from my own phone their K7 doesn't always ring, it's more than 50% of the time I'd say.  We are both on PM plans.  Gsmarena.com tells me the K7 is on android 6, but nothing about the radio types it has.  Could there be anything about the K7 that make it work intermittently with PM?
srlawren
@on2wheels I'm seeing two varaints of that phone:  X230I (for India) seems to have only 1900MHz (B2) 3G without 850MHz (B5), while the X230 (for Russia) seems to have only 850MHz (B5) 3G without 1900MHz (B2).  Since PM uses these two 3G frequencies for talk, having only one could definitely lead to intermittent issues with calls.  Probably not a great choice for us with Public Mobile, unfortunately.  EDIT: there is also a version for the Philippines, X230K, but the network details for it is not listed on GSM Arena.  (Source:  https://www.gsmarena.com/lg_k7_(2017)-8817.php)
on2wheels
I did a reset on it when i first got it, since I used it on PM for a bit.  I do see the networks now, thanks, and yes it has all the ones my own phone has. Seems odd that it's the only number i have issues calling.  Too bad none of my friends are with PM for me to get more data.
geopublic
@on2wheels  From a quick lookup online that phone only has the following bands:
4G: B5(850) & B7 (2600)
3G: None for NA?
2G: B2 & B5 (Will work on Rogers)
Edit: There is a NA T-Mobile version LG K7 4G K330 LTE if that is the one you have should work.
The K7 appears to me to be a bit on the edge. Maybe you have a more exact model number?
On gsmarena, notice the little Expand word on the right side of the Network heading. Clicking that gives you more radio details.
will13am
@on2wheels, this definitely sounds like a phone issue.  The fact that you are able to connect to the network and make a call means the bands are compatible.  Gsmarena information suggests this phone has both 3G and LTE compatible bands.  Intermittent failures is a sure sign of software bugs.  Have you tried a factory reset to see if that fixes the problem.
