LD message
01-16-2017 08:36 PM - edited 01-05-2022 01:35 AM
Hi. When I call same province starting 250... There is message " long distance charge may apply. ..." May I ignore this message? Or it will be charge extra?
Next question: As long as I do not have add on then I can not call to LD right?
Service
01-17-2017 04:58 PM
@avie nope, doesn't matter who is calling you. When it comes to incoming calls, all that matters is where you are located, and what your home province is.
01-17-2017 04:16 PM
Very interesting...I 110% do not have LD mins add-on.
Could it be that I was able to pick up because it was an Ontario number calling me? In addition, the call was originating from Montreal as well.
01-17-2017 01:46 PM
@WearySky wrote:
This is incorrect. If you're on a province-wide calling plan and are outside of your home province (the province where your area code resides), your phone won't even ring unless you have a long distance add-on. You can make outgoing calls within the province that you are currently in, but incoming calls are LD. Are you sure you didn't have an LD add-on on your phone when you received those calls in Montreal?
@avie I agree 100% with @WearySky--if you did manage to recieve incoming calls on a province-wide talk plan with no long distance add-on minutes available while outside of your own province, it must have been a fluke or a glitch. The normal and expected behvaiour is that incoming calls in that situation would go directly to your voicemail.
01-17-2017 12:36 PM
@avie wrote:I got that message before and was never charged LD.
On that point, you can be out of the province and still pick up phone calls without getting charged as well. AFAIK if you don't make outgoing calls while out of province, you're in the clear.
For reference: I have a Toronto number and travelled to Montreal. Picked up phone calls while I was there and bill had no charges.
01-17-2017 09:10 AM
01-17-2017 06:35 AM
01-17-2017 12:46 AM
Although it plays the message that "long distance charges may apply" as long as you are in the province, it will not apply, and as I found out that if you call outside the province with no add on (I only have province-wide calling) it won't let you complete the call
01-17-2017 12:25 AM - edited 01-17-2017 12:30 AM
01-16-2017 08:42 PM
That is correct. if you dial 1-250 you won't get that message
01-16-2017 08:42 PM
Ignore all messages when calling or texting. If they go through there will never be an extra charge. Public Mobile services are 100% prepaid; no overages ever.
01-16-2017 08:41 PM
If you have province wide talk then you cannot call other Canadian province without the LD add ons.
