Issues with transferring number
Kirajade
Just signed on with PM however I got a text message saying they’re having troubles transferring my number.
1 REPLY 1
Chalupa_Batman
Hey there. There is a number you can call to get this porting issue resolved. I will send you a private message to your mailbox in the top right corner of this page or click on this link to direct access.
You can also check here to see if you can port the number.
Check Eligibility to Move (koodomobile.com)
