03-22-2017 04:03 PM - edited 01-05-2022 01:51 AM
I have requested to port my number from Public Mobile to Rogers. Despite the fact that my plan with Public Mobile should be active until May, my number has been suspended after the porting request. What is the best course of action now to keep my previous number with Public Mobile and port it out to Rogers?
I have talked with Rogers and they asked me to talk with Public Mobile for this issue.
03-25-2017 08:22 PM
@khatabadi, because you requested the port via Rogers, it makes complete sense that your account is suspended, assuming the port completes. Also, your account will no longer be active until May, as the port cancels your account, and no refund will be provided.
03-24-2017 01:59 PM
Leaving PM to go to Rogers?
Sorry to hear...... ![]()
03-22-2017 04:49 PM
Ok. Perhaps I should have worded it more clearly:
"Normally, a port is done from the new carrier (i.e. Rogers). However, if Rogers says something is blocking it from Public Mobile's end then you should send a private message with your phone number to a moderator to look at your account."
03-22-2017 04:44 PM
Oh ok your original post could have been read that it was the other way
Normally, a port is done from the new carrier. However, if Rogers says something is blocking it from Public Mobile's end then you should send a private message with your phone number to a moderator to look at your account
This made it sound like you were saying that it was a port in from Rogers , with the Normally and However wording starting the sentences
03-22-2017 04:38 PM
@ShawnC13 wrote:@SD08, this port is being done by the new provider. This member is asking to port his PM number out to Rogers not in from Rogers. @khatabadi, as SD08 stated you are best to private message a mod and get this looked into ASAP I will tag a mod and you can click their name and send them a message. They will need your phone number and probably your SIM card number, and explain what issues you are having. @Mary_M are you around to look into this for this person
Yes, the port is being done from Public Mobile to Rogers. I wasn't suggesting it was done by PM.
03-22-2017 04:33 PM
03-22-2017 04:21 PM - edited 03-22-2017 04:30 PM
Normally, a port is done from the new carrier. However, if Rogers says something is blocking it from Public Mobile's end then you should send a private message with your phone number to a moderator to look at your account. How to contact moderators:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Contacting-our-Community-Moderators/ta-...
Just make sure you don't cancel your Public Mobile account before your port is complete, or the port will definitely fail.
