04-21-2017 12:47 PM - edited 01-04-2022 01:41 PM
I'm not yet with Public Mobile but hoping to join, and will be doing so if what I'm seeing on the website is correct. I am in BC. When I go to creat my own plan I am choosing the following:
- 90-day plan length
- Prince-Wide talk
- Global text
- 6GB/90 days of data
Plan costs are showing as $180 less discount of $96 for total of $84 before tax. I assume that's before auto-pay discount so I would be looking at $78 every 90 days or $26/mth. Seems too good to be true?
04-22-2017 11:09 AM
It appears there is no such 95 dollars without text.
I am trying to active one account as of now, and ya....
@Samianauman wrote:
95 dollars for 3 months not bad at all Plus if autopay selected then it's 89 💵 for 3 months
If you don't need text services
04-21-2017 07:29 PM
04-21-2017 07:27 PM
@nuidbu wrote:Because of the error,
I ordered two SIM card...What should I do now...
If you can't cancel and you are Toronto area, Private Message me, I'll buy one from you. Always good to have a spare. I won't pay double though. 🙂
04-21-2017 06:22 PM - edited 04-21-2017 06:23 PM
04-21-2017 06:20 PM
@nuidbu wrote:
So is this a price error or no?
If no, what's the charge for text messages? Pay per use?
This is the correct price. If you don't choose Global Text, you don't have texting capabilities at all. Public Mobile is totally prepaid so there is no "Pay per use" charges.
04-21-2017 06:15 PM
04-21-2017 06:11 PM
04-21-2017 01:54 PM
@nuidbu, you might be able to contact a mod and have the order cancelled if you wish. I am sure it hasn't been processed and shipped. If you have an email order confirmation number I would PM a MOD and explain your situation as to why you purchased the SIM cards. All the info on how to contact a mod can be found here
04-21-2017 01:33 PM
Yep sim doesn't expires so hang on to it maybe in future or summer time you find somthing more interesting which fulfill your needs
04-21-2017 01:31 PM
Thanks to the replies. No longer an "automatic buy" option like what I was seeing, but I will still consider PM when my current plan with VM expires.
04-21-2017 01:26 PM
Sorry about the confusion and all these system glitches everything working now check the plans now hopefully you will find something according to your needs
04-21-2017 01:24 PM
04-21-2017 12:50 PM
@VlntSpcmnSpff, it was a display glitch that has been fixed now. I believe if you look now it will show that plan at $120
04-21-2017 12:49 PM - edited 04-21-2017 12:50 PM
@VlntSpcmnSpff No, everything is glitched right now. Unfortunately, you won't make it pass activation. This would be a deal if it was.
