Is the Ulefone Note 11p compatible? Compatibility
holiests
I didn’t see this phone on the compatibility list, but it is a newer model. Does anyone know if it’s compatible?
2 REPLIES 2
@holiests
As mentioned above, the phone will work with Public mobile.
Here are the specs:
https://www.gsmarena.com/ulefone_note_11p-10711.php
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands1, 2, 3, 4, 5, 7, 8, 12, 17, 19, 20, 28
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).  band 12, band 5, band 2, band 1, band 4
  • HSPA: 850 MHz, 1900 MHz (UMTS).   B2, B5
 @holiests : Yes. Just because it's not on the list does not mean it's not compatible. Opening out that page also shows what a phone needs. You go look for that. That one does.
