04-23-2017 01:47 PM - edited 01-04-2022 01:42 PM
I purchased 1GB USdata roaming package via self serve.
I am now in California roaming on Tmobile.
I received confirmation the add on being successfully purchased. But when I landed there was not public Mobile sms saying I'm good.
Can a mod please confirm, Thank you.
04-26-2017 12:45 AM
04-26-2017 12:38 AM
Yup up and working well. Getting LTE in the majority of places, drops to 3G every once in a while when I'm in the office, but still adequate enough to use WhatsApp etc. Thanks again for the quick responses and help, much appreciated.
04-25-2017 12:27 PM
Let us know if it's working OP.
04-24-2017 01:15 PM - edited 04-24-2017 01:16 PM
@agaskin wrote:
I know, stupid question but I rather get confirmation before getting a huge bill.
You will never get a huge bill ... unless you pay everything up front and were asleep while you made those purchases but I haven't heard of anyone sleep-buying before. Like the others stated, pre-paid. When you use up the service or it exceeds the 10 days it stops working.
Also note - the 10 days started when you purchased the plan, not the day you arrived in the states.
04-24-2017 12:21 PM
@agaskin wrote:
I was anticipating a message to say roaming package is active, but the prepay answer would explain that.
Thank you again.
Yup, because it's prepaid, as soon as you purchase a roaming package it actually becomes active. PM isn't going to send you a message when you arrive in the US the way that other providers will.
04-23-2017 03:08 PM
Hey @agaskin,
If you are connected to a US network and you have Data Roaming enabled in your phone settings, you are good to go.
If you encounter any problems, send a private message to one of the mods in the community with your phone number to have any issues resolved asap.
04-23-2017 03:07 PM
As already mentioned, this is a prepaid service, so if the data is working then it is definitely coming from a successful addon purchase.
04-23-2017 02:27 PM
No problem
04-23-2017 02:13 PM
Re: "But when I landed there was not public Mobile sms saying I'm good."
Thank you again.
04-23-2017 01:51 PM - edited 04-23-2017 02:07 PM
About billing you won't since it's all prepaid it's more like you pay before you use service
i didn't get this part can you explain a bit
also since you in California data working as they suppose too if yes then you all set enjoy your time in California but keep a eye on usage
if data not working properly for you then try this
Find a wifi connection and login to your self serve and if u.s roaming showing in add on section also check your available funds if you see extra 20 dollars sitting in your available fund then add on haven't purchased properly yet since it's a 2 step process first you buy a addon by credit card money get transferred to your available fund then you buy addon again from your available funds if you see extra fund then follow the 2nd step hopefully that will resolve your issue if you having issues getting data working properly
but don't worry about billing since pm is truly prepaid service you won't get any charges automatically it's all pay before use system
