05-29-2018 09:50 PM - edited 01-04-2022 06:04 PM
Just got a new SIM card and I need to activate it.
https://activate.publicmobile.ca/ keeps timing out for me, across different browsers and devices. Is the website down, and is there an expected time before it's back online?
Thanks!
05-30-2018 11:15 AM
there is a survey email?
05-30-2018 03:50 AM
@Rockdaddy22 wrote:I think the customer is referring to the activation site not the self serve login.
That said, I’m not able to login to the self serve either.
Uhmm, i can log in just fine.
Did you also receive the survey email?
05-30-2018 03:38 AM - edited 05-30-2018 03:40 AM
05-30-2018 01:20 AM
I can't login in either.
05-29-2018 10:28 PM
Thanks for the confirmation!
There must have been something weird going on with my router/wifi. I was able to connect to the website by using a mobile hotspot.
05-29-2018 10:10 PM
Seems to be working fine on iOS using safari.
05-29-2018 09:59 PM - edited 05-29-2018 10:00 PM
@rvoogjarv No site maintenance at this moment! It works for me!
Try to clear browser's cache, use different browser, use Private / Incognito mode, turn off ad blockers.
