Ipad 2, - No Data working
08-07-2018 05:42 PM - edited 01-04-2022 06:40 PM
APN settings correct ( sp.mb.com), reboot cellular data activated - No Data working / I have tried everything Ipad 2 ver. 9.3.5 / 13G36 - activated sim card on-line and ipad shows Public Mobile and my cell number shows in settings but still no data... Do I need someone at public to activate something further so I may enjoy my $45 data plan? Please help me, buyers remorse setting in...
MrTrue
Joining Public
08-07-2018 06:23 PM
@mynamejc wrote:Correct me if I'm wrong but I believe there is an alternate APN that goes to isp.mb.com. Have you tried that?
The alternate APN does work from what I have read. It is not required though.
08-07-2018 06:19 PM
Is there some sort of network reset that is required?
08-07-2018 06:10 PM
no, still doesnt work... It shows 3G, Public Mobile with full service, data enabled but still nothing...
08-07-2018 06:05 PM
The iPad 2 is really old the bands and the ones it does have is very lacking.
https://www.gsmarena.com/apple_ipad_2_wi_fi_+_3g-3848.php
I was wrong before though when I suggested someone else here that their device wasn't compatible and they ended up getting it to work anyways with alternate APN settings from https://apn-canada.gishan.net/en/apn/public-mobile
08-07-2018 05:50 PM
From my phone here are the settings:
APN: isp.mb.com
Proxy: blank
Port: blank
Username: blank
Password:blank
MMSC: blank
MMS proxy: blank
MMS port: blank
MCC: 302
MNC: 220
08-07-2018 05:47 PM - edited 08-07-2018 05:49 PM
I have only tried the one... I will try it.. cheers and thank you
08-07-2018 05:46 PM
