Invoices
Lmckeach
I need invoices for Feb and March of this year. I can only see the last 3 months when I log in to my account. How do I go about getting these?
Lmckeach
Thank you @BKNS27 ! That solved the issue.
It would be more intuitive if the dropdown for the views (3mo/6mo/12mo) is seperate from/beside the filter button.
Thanks again! I appreciate the help 🙂
@Lmckeach
On the Payment History>Filter>there is a drop-down menu for 3 months, 6 months, 9 months, 12 months or Custom.
So click on 6 months then Download Receipt.
@Lmckeach
try this message link once again
if it does not work, manually go to your inbox
click the icon to compose new message, at the TO field, type CS_Agent and send them message
Lmckeach
Thanks for the advice. Same thing happened in Incognito mode. I have used the link you provided to  PM support.
@Lmckeach   you should see transaction for a full year on the transaction history page
https://myaccount.publicmobile.ca/en/account/payment/payment-history
Try again using Incognito mode just in case it is a browser issue.
If you really don't see more than 3 months, please message PM support and ask them to prepare you the invoices you need
