Invalid number error
rakesh
Trying to port from FM to PM.  During step 2 of activation, I enter my phone number and I get error saying number is invalid.  The number is definitely valid and in use.  What should I do?
If those ideas fail, activate the PM SIM by choosing a new number. Once your account and SIM function properly login to your account, and  port-in the FM number under Change Number. It is suggested in this thread:  https://productioncommunity.publicmobile.ca/t5/Getting-Started/Alternate-Phone-Number-Regex-Help/m-p...
Try on safari start from scratch.
Also use your chatr number on 1st page as a alternate number and then try freedom number on next step.
Also try different email address its usually happen when u had a past history with koodo telus or pm. That's why try a different email hopefully will fix the issue.
** I am not a Mod, please do not include any private info in a private message to me.**
rakesh
Used IE.  I have two numbers - one with FM and other with Chatr.  Chatr number works but FM number does not.
Samianauman
Try a different browser safari or ie.
