08-15-2020 01:27 PM - edited 01-05-2022 12:32 PM
12-04-2021 05:33 PM
08-15-2020 09:50 PM
for some reason public mobile website sometime show this errors and best to use another device and try and it worked with my friends
08-15-2020 01:38 PM
@Newguy2232 if you got that message the first time you tried to activate your SIM. Your SIM may be a bum one. Contact the moderators about it. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-15-2020 01:37 PM
@Newguy2232 hi the system can be finicky wait an hour as suggested don"t hit your back button or things get messed up
08-15-2020 01:29 PM
@Newguy2232 wrote:Hi keep getting invalid SIM when trying to activate.
Thanks,
K
@Newguy2232 hi try the live chat for activations https://www.publicmobile.ca/en/bc/plans
08-15-2020 01:29 PM
@Newguy2232 Try using incognito/private browsing mode. If not, try again in an hour or so when the previous session is cleared.
