Incoming calls not working
Sal1
Hi, new to this provider.  Didnt have previous carriers acct number when i set this up to port my pphone number.  Wondering how to get hold of moderator in order to get my number ported properly.
10 REPLIES 10
popping
@Sal1 wrote:
Thanks for replying, I am porting from Chatr, didnt have Chatr account number when i signed up at London Drugs so I think I have to give Public that number now that i have it.  Its just complicated for me on line as I'm not tech savy.....
Chatr online does not give your your account number and you need to call them to get your account number.
If you are still trying to get hold of moderator, your can try my procedure below:  I got a reply from moderator within 2 hours yesterday.  But your response may vary depending how busy they are.  YMMV.
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
Sal1
Thank you for the links...I've filled out a ticket...fingers crossed they get back to me....
Sal1
Thanks...no from Chatr...had to call to get acct number....they were closed, back east, now i have the acct number but how do i give it to Public....everything works except receiving calls. Have submitted a ticket...hope that works...
kselmak
Hi @Sal1
Did you already initiate the port?
Welcome to public mobile
Sal1
DOA
Just to add to what ddeep says, Bell/Virgin also uses the phone number as the account number.
ddeep91
Hello @Sal1 , are you porting your number from speak out?
If you are porting your number from speakout  >>>READ THIS<<< Post.
Cheers
In the meantime @Sal1  Insert your previous providers SIM and use it to receive call sand texts. Download a voip app such as TextNow and use it over WiFi to make/ recieve/ send calls and texts free.
Sal1
Thank you, I will give that a try....
geopublic
@Sal1
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
