11-06-2018 03:13 PM - edited 01-05-2022 02:25 AM
Hi there
I have switched my number from other company today. Since activation I can call outside but incoming calls are not getting . Can anybody help me out!!
11-07-2018 08:32 PM
https://crtc.gc.ca/eng/phone/mobile/num.htm
It should take only "a few hours" for mobile numbers, but may take 2 business days for landline numbers.
@Psygineer wrote:It can take considerably longer than 6 hours! It took a little over two business days for my parent's port to go through. They were coming off a landline. Started on Friday evening, finished Wednesday. It could be the old carrier being slow to release the number.
11-07-2018 08:02 PM
11-06-2018 04:00 PM
While you are waiting for moderator, you can continue to use your old SIM card until it is complete dead which is the indication of you number is completely ported to PM.
11-06-2018 03:22 PM
Thanks
11-06-2018 03:19 PM - edited 11-06-2018 03:20 PM
It can take up to about 6hrs for a port to complete. If it has been longer than that, you should contact the Moderator Team for them to look into it for you.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/The-Public-Mobile-Moderator-Team/ta-p/...
