Incoming Call question
jgorman
Hi
I have province wide calling. My question is if I'm out of my local area I understand I can't make long distance calls without an add on but will I still receive calls if I'm not in my calling area?
Thanks
srlawren
@daredogg wrote:
Simple way to look at it:  IF I LEAVE MY PROVINCE... I need a LD add-on.
@daredogg I love this summary!
You could slightly ammend it to read:
IF I LEAVE MY PROVINCE... OR I NEED TO PLACE CALLS OUTSIDE OF MY PROVINCE WHILE IN MY PROVINCE.... then I need an LD add-on
daredogg
Hope you got your answer @jgorman with the link Luddite shared.
Local calls are always free to make wherever you are. If you leave province (which is considered your local area) people cannot call you unless you have the LD add-on.
Luddite
Check out this post:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Province-wide-Canada-wide-and-Long-Dist...
