11-27-2018 09:46 PM - edited 01-05-2022 02:36 AM
I am trying to view the full body of the message by the moderator, but I can't. the message in the inbox pane was limited to certain length. How do you view the full message? Also how do you reply back to the moderator? I don't see a reply button.
11-27-2018 09:58 PM - edited 11-27-2018 10:01 PM
Click there
Then it will be like this below, the full message, then bottom right corner click reply
Remember to click "QUOTE" when replying to include the original message
When you want to send the message, click "send message" at the bottom right corner
11-27-2018 09:51 PM - edited 11-27-2018 09:58 PM
Just press on the subject section (below the Moderator Team title). Then the full message will show up and then you can see the reply button.
