07-07-2018 03:00 PM - edited 01-04-2022 06:24 PM
I complained earlier that my text allotment had been used up and I was unable to sent or receive texts. Just occurred to me to turn on iMessage which will allow me to message using the inexpensive PM data add on. . I'm back to messaging again but ofcourse I can only text to other iPhone users.
07-08-2018 02:13 PM - edited 07-08-2018 02:16 PM
@ohitora wrote:I complained earlier that my text allotment had been used up and I was unable to sent or receive texts. Just occurred to me to turn on iMessage which will allow me to message using the inexpensive PM data add on. . I'm back to messaging again but ofcourse I can only text to other iPhone users.
@ohitoraif you have Data plan, all text are unlimited with PM here ( mean text till you drop
Never mind, you was in cheap plan, I just read your other post
07-08-2018 12:06 PM
iMessage can be a bit glitchy, I recommend either completely disabling it or disable it and then re enable it. As long as your data is working iMessage should work so its most likely and apple issue.
07-08-2018 11:53 AM
Yes I did which seemed a no brainer at that time. But now I'm experiencing problems texting iMessages with PM data. As I posted recently when I'm away from a WIFI source and try to iMessage by PM data the messages show as sent but in fact are not.
07-08-2018 07:57 AM - edited 07-08-2018 07:57 AM
Alternatively, you could just change your plan as well. Public Mobiles plans are reletively inexpensive compared to other providers. https://www.publicmobile.ca/en/on/plans
07-07-2018 06:05 PM
I am a fan of Fongo, but for texts, I would go with Textnow instead. Textnow supports MMS messaging, which sadly, Fongo does not do well.
07-07-2018 03:25 PM
Yeah, go the wifi texting route... lots of apps and chances are most people you'd normally text are also using them
07-07-2018 03:23 PM
Yeah, you mentioned this before:
07-07-2018 03:09 PM
You could use a different Internet messaging app to text non iPhone users. Try Fongo
