09-04-2023
07:45 PM
09-04-2023
10:31 PM
computergeek541
Hi, dear sir or madam, how are you! This is Bella, I wanted to port my Fido number but I enter the wrong IMEI. COULD YOU PLEASE HELP?
Bella
09-04-2023 08:10 PM
Like @LitlLdy said, Do not use the IMEI Number when Porting in. Sucess rate is low.
Try with the Fido Account Number instead and that will work.
09-04-2023 07:51 PM - edited 09-04-2023 08:00 PM
@Bellayang wrote:Hi, dear sir or madam, how are you! This is Bella, I wanted to port my Fido number but I enter the wrong IMEI. COULD YOU PLEASE HELP?
Bella
@Bellayang , in order to port your phone number to Public Mobile you need to use your Fido Account # to port that phone number in not the IMEI ! 😞
Please send a private message to a CS_Agent for help with it.
You can send a private message to a CS_Agent using the link: -> https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
A CS_Agent will respond back in your Community mailbox (envelope icon) at the top right of this page to the left of your community avatar on your computer or by clicking on your avatar on your device.
I also sent you a private message for the phone number to call to help with porting your phone number in!
Edit: To fix my typos!
