IMEI
Namu
Hello again,
I have another question for you lovely community members. I need my IMEI number for my phone because it is so old that it's still locked to virgin. But a few of the numbers are rubbed off on the label so I can't quite see what the phone IMEI number is is there another way to get it?
@Namu wrote:
Thank you @Anonymous  I knew there was a code you could put in the phone.
@Namu
your welcome
i glad it works...
Namu
@LeePublic
I forgot about that too...trying to squint my way to see too tiny illegible digits! Thanks!
LeePublic
@Namu If it is a Android or iPhone, you can see the IMEI by going to the settings then about/general then you should see the IMEI.
@Namu
You can dial *#06# on your phone to get your IMEI number...
How to find the IMEI number on your Android phone:
  1. Open the Settings app on your Android phone.
  2. Scroll down and tap on About Phone.
  3. Scroll down and you will find the number under IMEI.
How to find the IMEI number on your iphone visit Here link.
LeePublic
@Namu What model is it? Do you have the box the phone came with? Is it a smartphone?
