09-24-2019 12:05 AM - edited 01-05-2022 07:15 AM
I have looked everywhere for the IEMI checker but can’t find it anywhere. Can someone let me know if this IEMI number will work on the PM network.
Joining Public
10-02-2019 12:07 PM
http://www.imeipro.info/ your phone should work with Public as long as it is unlocked or with Telus or Koodo and long as it isn't blacklisted.
09-25-2019 05:14 PM - edited 09-25-2019 05:18 PM
Both the phone compatibility and IMEI checker are back today! 😄
09-24-2019 11:58 AM
@Matthieu_C wrote:Right?! Does anyone from PM understand why the link is there but there is no place to type in the IMEI number?
The link at the bottom just goes to the same Get Started page where the checker has been removed.
Maybe it was too much hassle keeping up the database of compatible phones and then also that blacklisting can be checked elsewhere like the link I provided.
09-24-2019 11:46 AM
09-24-2019 12:22 AM - edited 09-24-2019 12:22 AM
@Matthieu_C wrote:I have looked everywhere for the IEMI checker but can’t find it anywhere. Can someone let me know if this IEMI number will work on the PM network. xxxxxxxxxx
Interesting. It used to be under Get Started. It seems to be gone.
Try devicecheck
09-24-2019 12:18 AM
It used to be on the Getting Started page but they removed it for some reason! There is still even a link at the bottom of the page that says "Check Your Phone". Weird!
09-24-2019 12:10 AM
@Matthieu_CYour Samsung should work with Public Mobile as long as it is not black listed.
