05-04-2015 05:43 AM - edited 01-04-2022 01:27 PM
I will be travelling U.S.A. shortly for a few days and how can I buy a Roaming Facility add on for this few days ? Any suggestion? Thanks in advance.
Service
05-04-2015 11:35 AM
Hi @siv_sarkar - Here is the link to the post that @Martin referred to - Phone Unlocking.
Hope you are able to find the reliable solution to roam in the U.S.
05-04-2015 11:32 AM
Once you receive code you just plunk a different carrier sim in and it prompt you for the code supplied by the eBay seller.
Easy peasy
05-04-2015 07:36 AM
Cellunlocker.net tends to have a good reputation.
If you enter "unlocking" in PM's search engine, a lengthy article by David will be displayed. On the mobile version, the search engine is characterized by a magnifying glass in the top left corner.
In terms of how to unlock, ask the various merchants until you become comfortable with the process. Ask questions!
At the very least, you need your phone's IMEI.
Good luck!
05-04-2015 06:52 AM
Thank you, I browsed the www.roammonility.com website. However, I am not comfortable yet about buying an unlocking service from e-bay. There are a host of companies and I am really not sure who is really credible, and whose service is compatible for my device. I am still investigating. Besides, the technical issue is another headache for me, I have not sure how to unlock a phone. Still looking puzzled!!!
05-04-2015 06:02 AM
Roam Mobility is located at roammobility.com
In order to use its services, your phone needs to be unlocked.
The company caters especially to Canadians, visiting the USA and Mexico.
Instead of paying $50 to unlock your phone, you can pay $5 or so by shopping on eBay, looking for a credible unlocking company.
Public Mobile does not sell roaming features.
