I put the wrong referral code
chidungdoan56
Hi ,
I just activated my new phone number but I wrongly put the referral code. Please advise how I can correct it.
Thank you
@chidungdoan56  As @popping  has suggested the only way to correct a referral code is with a moderators help. Create a ticket via simon (?) On bottom right of your screen. Fill it out describing your problem and submit it. Wait up to 48 hrs for a response. Check your private msg box periodically or sign up for an email alert.
cavemantoronto
@chidungdoan56 wrote:
Hi ,
Thank you
Did it say invalid code? I don't think it lets you continue. Was it someone else's code?
popping
Hi ,
Thank you
Create a moderator support ticket using the ? button at the bottom right hand corner of this page.  Moderator wait time is up to 2 days.
