I need to Port my Line Out
MideHamzat
The text message verification is failing. Please manually approve
hi @MideHamzat
PM agent won't help to approve.
But you can discuss with that on the issue and try to fix the texting issue first.  Please  submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
MideHamzat
Rogers
@MideHamzat
As note by @hTideGnow . Everything is done internally between carriers so you need to contact your new carrier.
Who is your new carrier?
MideHamzat
I did that. The text verification does not seem to be working. You need to manually appprove it please
hi @MideHamzat
you have to ask your new provider to resend the porting request to PM and then PM will resend you the porting authorization text
of course, make sure your PM account is active and and is able to receive text
