I need my puk number
Swinny420
I can't really do anything else to explain to my phone service not working
2 REPLIES 2
Swinny420
Puk number
Sansan
@Swinny420  so is it a puk code you need or your phone's not working? These would be separate issues.
Check this link for scenarios for puk code.
https://urlshortner.tiia.ai/Oyn1L6
If your phone is not working,  can you receive incoming calls but no outgoing calls? What type of phone do you have?  If you have a physical SIM card,  try the card in another phone to test and see if the issue is the phone.
Have you also tried resetting networks?
