I need help
01-10-2018 06:32 PM - edited 01-04-2022 03:17 PM
I have a new phone number and my login email I don't remember. How can I access my bill?
My Account
01-10-2018 06:57 PM
@Chris_edmunds Did you use a different email for your account here? If you're pretty sure it's the same you could click the icon in the corner and go to My Profile. Your email associated with your community account will be listed there which I'd recommend being the same as the one you used to sign up for PM.
01-10-2018 06:44 PM
@Chris_edmunds, if you can't remember your email you will need to private message a MOD.
- PM Phone Number
- 4 digit PIN (if you don't remember this then they will need at least 3 of the following to verify your identity)
- account number
- date of birth
- complete address listed on account with postal code
- email address on account
- most commonly called numbers
- alternate number listed on the account
- last payment date and amount
- last 4 digits of the credit card
- Detailed explanation
