02-13-2020 02:02 AM - edited 01-05-2022 10:37 AM
I accidently bought a us data for 20 and wanted to buy two 10$ data here in Toronto I sent in a ticket to mod and I hope they can change it for me
02-13-2020 08:10 AM
@Bk2020 Keep us posted on the outcome.👍
02-13-2020 07:37 AM
@Bk2020 did you sign up under the Lunar promotion ? Don't switch, you will lose it. Instead, try to conserve data. Do such things as enable updates over WiFi, turn off all apps from using background data but the essentials ones. You could turn data off and enable it only when you need it and to send/recieve mms messages.
I'm wondering why you would buy 400mb of data for $20, when for $30 you can get 1gig. Also, which plan are you on? If you run out of data every month and have to spend $20, then you should look for a plan with more.
If you didn't sign up during the Lunar promotion , then consider switching up. Check to see if there are any bonuses that you may lose, depending upon when you signed up. If you are unsure, post the date and month joined, the applicable bonus and ask here. Also if you do decide to change your plan, set the change to start on your next cycle, do not change immediately, because you will lose both the remaining balance in your current cycle and be charged for The new one.
02-13-2020 03:20 AM
I wish you can get credit back.
02-13-2020 02:06 AM
They are usually pretty good with honest mistakes. You should get an account credit.
