yesterday - last edited yesterday by computergeek541
I check the eSIM compatibility- it was compatible.
continued with registration - now saying not compatible - need help
please contact me
yesterday
Just curious why the search was eSIM compatible but during activation it indicated it wasn’t compatible.
yesterday
@BKNS27 wrote:What is the make and model of your phone?
The customer has received an error message saying that the device isn't eSIM compatible. There isn't any way to override that even if the phone should be compatible with an eSIM.
yesterday
yesterday
@UltraTravis No one will contact you , to engage support you need to message them
@UltraTravis wrote:I check the eSIM compatibility- it was compatible.
please contact me
Customer service doesn't usually contact customers. You'll need to contact them.
Please open a ticket using the chatbot.
If the chatbot, doesn't allow a ticket to be opened, send a private message to the username CS_Agent. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
